fpga dev tools quartus® prime software pro
4369 TopicsWhy is there a Verilog HDL warning that delay control is not supported for synthesis when using the Intel FPGA MII to RMII Converter Core?
Description Due to a problem in the Quartus® Prime Pro Edition Software version 26.1.1, the following Verilog HDL warnings might appear during synthesis when a design includes the MII to RMII Converter Core IP: Warning: Verilog HDL warning at intel_fpga_mii2rmii.sv(344): delay control is not supported for synthesis Warning: Verilog HDL warning at intel_fpga_mii2rmii.sv(345): delay control is not supported for synthesis The warnings are caused by zero-delay controls in the IP HDL. Quartus® synthesis ignores these delay controls, and there is no functional impact on the compiled design. Resolution You may safely ignore these warnings. There is no functional impact. This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 27.1.17Views0likes0CommentsWhy does the SD/eMMC U-Boot driver fail to select the SDR12 mode for Agilex® 5 FPGA and Agilex® 3 FPGA devices in release 25.3.1 release and before?
Description Due to a problem in the U-Boot SD/eMMC driver in Agilex® 5 FPGA and Agilex® 3 FPGA devices in release 25.3.1 and before, U-Boot fails to select the SD SDR12 mode regardless of using the sd-uhs-sdr12 parameter in the device tree. The reason behind this problem is that the driver tries the SD_HS (50 MHz) mode first, so if this succeeds, then the SDR12 (25 MHz) is not tried. Because of this problem, currently, there is no direct method to force the driver to choose SDR12 mode. Resolution To workaround this problem, you need to use the following configuration in the device tree along with the SD/eMMC driver source code modification: 1. U-Boot device tree configuration: Remove no-1-8-v: Allows the MMC stack to perform voltage switching to 1.8V, which is required for UHS modes Remove cap-sd-highspeed: Ensures SDR12 becomes the highest priority mode available Add sd-uhs-sdr12: Explicitly declares SDR12 support &mmc { status = "okay"; no-mmc; disable-wp; //no-1-8-v; // Remove or keep commented out //cap-sd-highspeed; // Remove or keep commented out sd-uhs-sdr12; // Add this property vmmc-supply = <&sd_emmc_power>; vqmmc-supply = <&sd_io_1v8_reg>; max-frequency = <200000000>; sdhci-caps = <0x00000000 0x0000c800>; sdhci-caps-mask = <0x00002007 0x0000ff00>; // ... (rest of PHY timing configuration remains unchanged) }; 2. Modify the U-Boot drivers/mmc/sdhci-cadence.c source code as follows: You must update the host->quirks parameter to disable the SD High Speed mode at the driver level, providing an additional safeguard to ensure SDR12 is selected. static int sdhci_cdns_probe(struct udevice *dev) { : host->quirks |= SDHCI_QUIRK_WAIT_SEND_CMD; host->quirks |= SDHCI_QUIRK_BROKEN_HISPD_MODE; // Add this line : } This problem will be fixed in a future release.128Views0likes0CommentsWhy does niosv-download download ELF file incorrectly into the 1st device despite that the --device is specified to 2nd device?
Description Due to a problem in the Quartus® Prime Edition’s niosv-download device indexing function, niosv-download might incorrectly download ELF file into the 1st device, despite --device is specified to the 2nd device. This problem affects both, niosv-download with OpenOCD (Using --use_openocd) niosv-download with Ashling* GDBServer (Not using --use_openocd) This problem only happens with two similar FPGA devices with Nios® V design in each of the devices that resides on the same JTAG chain. You are not impacted, If only one of the FPGA device have Nios® V design. If the FPGA devices has different OPN. Resolution Download Type 1: niosv-download with OpenOCD (with “--use_openocd”) Do not use the --use_openocd option. Instead: Use niosv-download with the Ashling* GDBServer download flow (without --use_openocd). Install Patch 0.42 described below. This problems (niosv-download with OpenOCD) is currently scheduled to be resolved in a future release of the Quartus ® Prime Edition Software. Download Type 2: niosv-download with Ashling* GDBServer (without “--use_openocd”) Install Patch 0.42 for Quartus® Prime Pro Edition Software v25.3. Patch Download: Quartus® Prime Pro Edition Software v25.3 Patch 0.42 (Windows/Linux) quartus-25.3-0.42.zip This problems (niosv-download with Ashling* GDBServer) is resolved in Quartus ® Prime Pro Edition software version 26.3, and scheduled to be resolved in a future release of the Quartus ® Prime Standard Edition software.13Views0likes0CommentsWhy does the GTS AXI Streaming IP for PCI Express* on Agilex® 5 FPGA D-Series remain in reset or fail to initialize after system boot?
Description Due to a problem in the Quartus® Prime Pro Edition software version 26.3, the GTS AXI Streaming IP for PCI Express* on Agilex® 5 FPGA D-Series devices may not initialize successfully. Devices programmed with a .sof file or an image generated by version 26.3 may exhibit the following symptoms: The PCIe IP remains in reset. The PCIe endpoint fails to enumerate. These symptoms may occur even though device configuration and overall system boot-up have completed successfully. Impacted Agilex 5 OPN A5Dx160xxxxxxRx Resolution A software patch is available to resolve this problem in the Quartus Prime Pro Edition software version 26.3. To install the fix: Download Patch 0.05fw for your operating system. Install Patch 0.05fw into your Quartus Prime Pro Edition software version 26.3. The patch files are available below: quartus-26.3-0.05fw-windows.exe quartus-26.3-0.05fw-linux.run After installing the patch, recompile the design or rerun the Assembler process in the Quartus Prime Pro software to generate a new configuration image containing the updated firmware for hardware test.82Views0likes0CommentsHow to adjust GTS PMA fractional PLL frequency in simulation?
Description The GTS Transceiver PHY User Guide describes the sequence to change GTS PMA Fractional PLL frequency as follows. However, in simulation, after step 1, the frequency will reflect the new value without needing to execute step 2. This issue only exists in simulation. In hardware testings, you still need to follow the User Guide guidelines. Tuning the k Counter Value in Fractional Mode You can configure the GTS PMA in fractional mode to adjust the frequency and data rate by +/- 1000ppm for rate matching purposes. Each GTS PMA has an Avalon® memory-mapped interface register containing the K value. The K value / 2^22 gives the fractional value of the feedback counter. The fractional value plus the M counter value provides the total feedback counter and determines how much PPM each bit in the K value represents. The procedure to change the K value is: Change the K value to the new value. Pulse the strobe bit 0 -> 1-> 0 to lock in the new K value. Resolution In hardware testing, you need to follow the User Guide guidelines. In simulation, you can perform the step 1 only. There is no plan to fix the problem.15Views0likes0CommentsWhy does the F-Tile System PLL fail to lock when the reference clock is active only after configuration?
Description You might observe the F-Tile System PLL lock failure when your design has both below requirements: More than one System PLL are enabled in one F-Tile, e.g. syspll0 and syspll1 One System PLL reference clock source will only be active after the other System PLL is locked. E.g. syspll0 refclk is active only after syspll1 is locked. Failure Symptom: The later System PLL will never lock. E.g syspll0 refclk is active only after syspll1 is locked, then syspll0 could never lock. Background: When a System PLL reference clock source is not active at configuration, then all System PLL reference clock must unselect parameter And the F-Tile Reference and System PLL Clocks FPGA IP will expose below control signals for each System PLL: refclock_ready[n] en_refclk_fgt_i Expected behavior: For each System PLL #n, after its reference clock source #i is active, then we can drive refclock_ready[n] and en_refclk_fgt_i to get System PLL #n locked independently from other System PLL. Root Cause: The SSM (Secure Socket Manager) firmware and SIP workaround use a single on/off indication rather than separate handling for each SysPLL. Once any bit of refclock_ready[2:0] asserted, (refclock_ready[2:0] ≠ 3'b000), all enabled system PLLs start locking to the incoming reference clock. If the reference clock of a system PLL is not available before you assign the refclock_ready[2:0] ≠ 3'b000, then the corresponding system PLL will not lock unless you reconfigure the device. Resolution To work around the problem: After all system PLL refclk #i is active, you need to assert any bit of refclock_ready[2:0] (refclock_ready[2:0] ≠ 3'b000), wait for refclock_status assertion. After refclock_status assertion, then assert each en_refclk_fgt_i, wait for corresponding refclk_fgt_enabled_i assertion. There is no plan to fix this problem.169Views0likes0CommentsWhy does generating an HDMI IP Design Example fail when selecting "No Daughter Card" in the Quartus® Prime Pro?
Description Due to a problem in the Quartus® Prime Pro Edition software version 26.1.1, generating an F-Tile HDMI FPGA IP design example encounters an error under the following configurations: Daughter Card parameter set to "No Daughter Card" with No Development Kit selected. Daughter Card parameter set to "No Daughter Card" with a Development Kit selected. Symptoms & Affected Components: Failure: Design Example generation fails or produces an error in Platform Designer Affected IP: F-Tile HDMI FPGA IP (ip.Video Connectivity.HDMI) Target Device / Architecture: Agilex® 7 / F-Tile devices Cause: The F-Tile HDMI IP design example generation script relies on a selected daughter card definition to automatically generate required board topology, clocking, and transceiver constraints. Selecting "No Daughter Card" causes error in the generation script in the Quartus Prime Pro Edition software version 26.1.1. Resolution To work around this problem, follow the steps below. Open the F-Tile HDMI FPGA IP parameter editor. Under the Design Example tab, select a supported HDMI Daughter Card option instead of "No Daughter Card". Generate the design example. If targeting a custom board, manually update the generated top-level pin locations and clock/transceiver settings in your project to match your custom board requirements. Patches are available to fix this problem for the Quartus Prime Pro Edition Software version 26.1.1 versions. Download and install patch below. Quartus Prime Pro Edition Software v26.1.1 Patch 1.25 This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.21Views0likes0CommentsWhy does the Linux* EDAC driver report "Previous Boot UE detected[0x40000]" on Agilex® 7 FPGA F and I-Series SoC FPGA devices?
Description The Linux* EDAC driver (drivers/edac/altera_edac.c) in the SoCFPGA Linux 6.12.11-lts (and earlier versions) may print a false Uncorrectable Error (UE) message during driver probe on Agilex® 7 F/I series SoC FPGA platform, as shown below. EDAC Altera: Previous Boot UE detected[0x40000] @ 0x0 The EDAC driver maps BOOT_SCRATCH_COLD8 (offset address0x220in System Manager, absolute address 0xFFD12220) to S10_SYSMGR_UE_VAL_OFST and treats any non-zero value as evidence of a previous boot UE event. At probe time, the driver checks: if (dberror) { ... } instead of properly masking with: if (dberror & AGX7F_I_DBE_IRQ_MASK) { ... } The valid UE sticky mask AGX7F_I_DBE_IRQ_MASK(0x30002) covers bits 1/16/17 only. When the value of BOOT_SCRATCH_COLD8 is 0x40000 in which bit 18 represents the SDM ACF DDR data rate per the Agilex 7 F/I SoC FPGA register definition, but it’s reported as a DDR UE/DBE by Linux EDAC driver by mistake. The driver does not account for the differences among the various Agilex 7 device series or for future device families. BOOT_SCRATCH_COLD8 bit definitions: Bit field Agilex 7 F/I-Series Agilex 7 M-Series Values / description Usage or source [31] Available as scratch memory DBE Triggered Flag M-Series:0: DDR DBE not triggered; 1: DDR DBE triggered U-Boot ddr_ecc_dbe_status(): evaluates DDR ECC DBE status [30] Available as scratch memory DDR Init in progress M-Series:0: DDR initialization not performed or completed successfully; 1: DDR initialization in progress U-Boot is_ddr_init_hang() checks the bit; ddr_init_inprogress() sets or clears it [29] Available as scratch memory OCRAM_DBE Error Flag M-Series:0: error did not occur; 1: error occurred U-Boot hps_ocram_dbe_status() returns OCRAM DBE status; ddr_init_inprogress() sets or clears it [28:27] Available as scratch memory Number of IO96B instances assigned to HPS M-Series:Written during DDR handoff data population U-Boot update_io96b_assigned_to_hps() [19] Flag indicating that a CPU power domain is about to be turned on; value 1 Flag indicating that a CPU power domain is about to be turned on; value 1 F/I/M-Series:A value of 1 indicates that the CPU power domain is about to be turned on ATF socfpga_pwr_domain_on() [18] ACF DDR data rate set by SDM Available as scratch memory F/I-Series: 0 = half-rate; 1 = quarter-rate U-Boot sdram_mmr_init_full() uses the value to configure DDRIOCTRL [17] ECC_DBE_DDR1 Error Flag ECC_DBE_DDR1 Error Flag F/I/M-Series:0: error did not occur; 1: error occurred ATF cold_reset_for_ecc_dbe() checks the flag; Linux sets it through the ATF SMC handler [16] ECC_DBE_DDR0 Error Flag ECC_DBE_DDR0 Error Flag F/I/M-Series:0: error did not occur; 1: error occurred ATF cold_reset_for_ecc_dbe() checks the flag; Linux sets it through the ATF SMC handler [1] ECC_DBE_OCRAM Error Flag ECC_DBE_OCRAM Error Flag F/I/M-Series:0: error did not occur; 1: error occurred ATF cold_reset_for_ecc_dbe() checks the flag; Linux sets it through the ATF SMC handler Impact: No actual DDR UE event is indicated by 0x40000. The false-positive log does not trigger kernel panic, reboot, or EDAC fault handling. However, the driver executes a full register write of zero to both BOOT_SCRATCH_COLD8 and BOOT_SCRATCH_COLD9 after printing the message, which may clear other valid scratch data (ATF, SDM, DDR progress bits) used by boot software on subsequent resets. Real DDR ECC uncorrectable errors continue to be reported correctly through the runtime ECC interrupt path (ECC_INTSTATUS_DERR @ sysmgr +0xA0). Resolution A patch has been applied to remove the incorrect previous DBE check using the BOOT_SCRATCH_COLD8 register during EDAC driver probe. ES-14508: EDAC/altera: Remove previous DBE check using boot scratch c… · altera-fpga/linux-socfpga@d06daa2 Related Articles A.7. BOOT_SCRATCH_COLD8 - 2025-12-16 linux-socfpga/drivers/edac/altera_edac.c at socfpga-6.12.11-lts · altera-fpga/linux-socfpga22Views0likes0CommentsWhy do I unexpectedly observe intermittent DDM Errors?
Description Beginning January 10, 2026, executing commands in the terminal or GUI of Quartus® Prime Pro Edition software, Quartus Embedded Edition software or select standalone tools may cause the software or tool to crash with an error similar to the crash signature shown below. This error affects: Quartus Prime Pro Software versions v22.1 through v25.3.1 Standalone Quartus Prime Pro Programmer v22.1 through v25.3.1 Standalone Quartus Prime Pro Embedded Edition v25.3 and v25.3.1 Standalone Quartus Prime Pro Power Thermal Analyzer v25.3 through v25.3.1 This issue is not observed in Quartus Prime Pro Edition versions 22.1 or prior or Quartus Prime Standard Edition. Crash Signature: Error (22912): Unhandled exception: Fatal Error: Assertion failed tools/cpp/ddm/ddm_assessor.cpp:53: DDM_T::verify_token(token) : Cannot identify the client from function assertion_error in tools/cpp/ddm_report/ddm_report_msg.cpp@465 *** Fatal Error: Program termination requested *** *** Below is the stack trace at the time the error occurred. *** The lines beginning "Err Handler" represent frames relating *** to generating this report. *** The point at which the error occurred is somewhere after these lines. *** There may be a few frames representing standard/library code *** before the Quartus frames begin. *** The search for the error should begin with the Quartus frames. *** Unwinder: libunwind *** Stack depth: 15 Quartus 0x24e67: err_terminator() + 0x1bc (ccl_err) Quartus 0xb036a: __cxxabiv1::__terminate(void (*)()) + 0xa (stdc++) Quartus 0xb03d5: (stdc++) Quartus 0xb0628: (stdc++) Quartus 0x1680d: void ddm_throw<DDM_RUNTIME_ERROR>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x26d (ddm_report) Quartus 0x13fae: DDM_REPORT::DDM_ASSERTION_HANDLER::assertion_error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) const + 0xde (ddm_report) Quartus 0x12a52: DDM_REPORT::ASSERTION_HANDLER::error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) + 0x72 (ddm_report) Quartus 0x13e64: DDM_REPORT::detail::assert_at_line(char const*, char const*, int, char const*, ...) + 0x1b4 (ddm_report) Quartus 0x205fb0: ddm_set_lassessor(DDM_T_ASSESSOR*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x60 (ddm) Quartus 0xf4445: DMS_MANAGER::DMS_MANAGER() + 0x5c5 (dni_dms) Quartus 0xf45b2: DMS_MANAGER::get() + 0x7a (dni_dms) Quartus 0xf6db4: _GLOBAL__sub_I_dms_manager.cpp + 0x58 (dni_dms) Quartus 0x647e: (ld-linux-x86-64) Quartus 0x6568: (ld-linux-x86-64) Quartus 0x202ca: (ld-linux-x86-64) Resolution To work around this problem: For Windows machines Download and unzip the Quartus Prime Pro version zip file that matches your Quartus Prime Pro version from this KDB. Double click on the executable ending in “windows.exe”. When the GUI pops up, press Next. Note that the GUI may look slightly different depending on the version of Quartus you are using. Accept the license agreement Specify the directory where the patch needs to be applied which may be a different location than Quartus install if you have standalone tools in a different directory from your Quartus Prime Pro software installation. Keep “Allow Patch to be uninstalled” selected. Select the software in which to install the patch: The patch will install in the directory of the software or tool you have selected. You will see an uninstall directory for the patch in your software or tool folder where patch is installed; it will contain an executable to uninstall the patch if required for any reason. To confirm patch is installed, you can run quartus_sh -v or corresponding version command for your tool via command line. Alternatively, you can Open Quartus in the GUI and select Help → About Quartus Prime in the main menu. If you are opening up a standalone tool you will navigate to Help-> About <tool_name>. For the Command Line Implementation of the patch in Windows, use the following command: <patch_filename.exe> --mode unattended --installdir <your_install_directory> --accept_eula 1 --patch_to [quartus|qprogrammer|qemb|pta] # An example to patch Quartus Prime Pro Edition Software v25.3: quartus-25.3-0.27-windows.exe --mode unattended --installdir /tmp/altera_pro/25.3 --accept_eula 1 # An example to patch the Standalone Programmer for Quartus Prime Pro Software v25.3: quartus-25.3-0.27-windows.exe --mode unattended --installdir /tmp/altera_pro/25.3 --accept_eula 1 --patch_to qprogrammer For Linux machines: Download and unzip the Quartus Prime Pro version zip file that matches your Quartus Prime Pro version from this KDB. Ensure you run chmod +x on the file ending with linux.run. Run in the command line: ./<installation_patch_run_file>. When GUI pops up, press Next. Note that the GUI may look slightly different depending on the version of Quartus you are using. Accept the license agreement Specify the directory where the patch needs to be applied which may be a different location than Quartus install if you have standalone tools in a different directory from your Quartus Prime Pro software installation. Keep “Allow Patch to be uninstalled” selected. Select the software in which to install the patch: The patch will install in the directory of the software or tool you have selected. You will see an uninstall directory for the patch in your software or tool folder where patch installed; it will contain an executable to uninstall the patch if required for any reason. To confirm patch is installed, you can run ./quartus_sh -v or corresponding version command for your tool via command line. Alternatively, you can Open Quartus in the GUI and select Help → About Quartus Prime in the main menu. If you are opening up a standalone tool you will navigate to Help-> About <tool_name>. For the Command Line Implementation of the patch in Linux, use the following command: ./<patch_filename.run> --mode unattended --installdir <your_install_directory> --accept_eula 1 --patch_to [quartus|qprogrammer|qemb|pta] # An example to patch Quartus Prime Pro Edition v25.3: ./quartus-25.3-0.27-linux.run --mode unattended --installdir /tmp/altera_pro/25.3 --accept_eula 1 # An example to patch the Standalone Programmer for Quartus Prime Pro Software v25.3: ./quartus-25.3-0.27-linux.run --mode unattended --installdir /tmp/altera_pro/25.3 --accept_eula 1 --patch_to qprogrammer This problem has been fixed in Quartus® Prime Pro Edition Software version 26.1. The below table lists the patches that are available and the associated patch number. The patch zip files are attached to the KDB below: Quartus Prime Pro Edition Version Patch Number 22.1 0.51 22.2 0.63 22.3 0.56 22.4 0.51 23.1 0.63 23.2 0.63 23.3 0.52 23.4 0.70 23.4.1 1.01 24.1 0.52 24.2 0.64 24.3 0.35 24.3.1 1.29 25.1 0.36 25.1.1 1.31 25.3 0.27 25.3.1 1.0215KViews5likes0CommentsWhy do I see Error (18950), Error (18948) and Error (209012) when program SOF file for Agilex® 5 FPGA device in Quartus® Prime Pro Edition version 26.3 ?
Description You may encounter programming failure in Quartus® Prime Pro Edition Software version 26.3 with an Agilex® 5 FPGA device SOF File. The operation fails with the following errors: Error(18950): Device has stopped receiving configuration data Error(18948): Error message received from device: Failed to load firmware due to authentication failure. Ensure the firmware is signed with the correct signing key. Error(209012): Operation failed Impacted Agilex 5 OPN A5Dx160xxxxxxxxRx Resolution A patch is available to fix this problem for the Quartus® Prime Pro Edition version 26.3. Download and Install patch below. quartus-26.3-0.05fw-windows.exe quartus-26.3-0.05fw-linux.run quartus-26.3-0.05fw-readme.txt Related Article Agilex® 5 FPGA Part Number Decoder121Views0likes0Comments
